stability in 3ds 2023 - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: stability in 3ds 2023 (/thread-3591.html) |
stability in 3ds 2023 - hkroeber - 03-30-2023 Hallo since i updated to max23 and the newest tyflow i noticed a few max crashs when working with particles. Are there any issues known? the problem exists in different situations. For the moment i switched back to max21. I hope it is a max23 problem. Regards H.Kroeber RE: stability in 3ds 2023 - hkroeber - 03-30-2023 After switching back to max21 i have the same issues. iit seems to be that if i cancel a simulation with Esc and go back to frame 0 quick max crashes. Regards H.Kroeber RE: stability in 3ds 2023 - tyFlow - 03-30-2023 The only known issue which causes consistent crashes in the latest build is a bug which can cause a crash if you use a native wind or gravity spacewarp in your flow. I'm not aware of any other crashing issues, and that bug will be fixed in the next build. If that bug isn't related to the behavior you're experiencing, please send me the mindiump and/or scene file. |
