Problems exporting TyTerrain sequence in History-independent mode - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Problems exporting TyTerrain sequence in History-independent mode (/thread-3594.html) |
Problems exporting TyTerrain sequence in History-independent mode - ferabachini - 03-31-2023 I'm not able to export a coherent sequence of tyterrain maps in a scene where I had to animate several parameters in histort-independent mode to make a landscape change constantly through keyframes. It is noticed that the cache is not generated correctly, but when taking a preview after I generate the cache of each frame, everything looks fine, however when I go to export the terrain maps, they behave completely differently in the animation. Attached is a video where I show the problem, I tried to export with normalize and without in the height channel, but all the maps come out with a wrong simulation, different from what is shown in the viewport after the first frame, regardless of the options I tested. RE: Problems exporting TyTerrain sequence in History-independent mode - tyFlow - 03-31-2023 Hmm, that does seem odd. Could you upload the file (or send to support@tyflow.com) so I can examine it directly? RE: Problems exporting TyTerrain sequence in History-independent mode - ferabachini - 03-31-2023 Ok, as it is a client project, I sent it to the email with a copy of the message so you can check it out. |
