cpu thread? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: cpu thread? (/thread-3693.html) |
cpu thread? - rheogh - 06-01-2023 Hi, cpu auto mode is the default value in the tyflow menu According to docs, the default is the maximum number of available However, other tasks were possible even if the number of cpu threads was the maximum Is the default to use the maximum number of threads? And If you don't know how many threads I have If you enter the number of threads in 999 Does it apply as the maximum value?? RE: cpu thread? - tyFlow - 06-03-2023 No, entering 999 won't spawn 999 threads. Internally the number of threads is limited to [max processors - reserved processors]. The minimum number of reserved processors is 1, because using all available processors will usually result in a significant performance hit (due to the fact that while Max is running Windows is still performing other tasks and needs at least 1 processor to do them). Leaving a single thread available (unless you're on a machine with only 1 processor...then tyFlow will indeed use all processors) will prevent a bottleneck like that. RE: cpu thread? - rheogh - 06-04-2023 I know that even if you enter 1.999 threads, 999 threads will not be created For example, if the maximum number of threads I have is 24, and I don't know the maximum number of threads I have Does entering 999 apply to the maximum number of threads, 24? 2. Simply put, if you turn it to auto, it's right to turn it to the maximum Are you saying that you leave a single thread to prevent performance degradation? Am I right in my understanding? RE: cpu thread? - tyFlow - 06-04-2023 It caps the total at the maximum number, yes. The 'reserved processors' parameter controls how many processors are left to the system to prevent degradation. RE: cpu thread? - rheogh - 06-04-2023 I bought tyflow pro because I trusted you It's so hard to answer and I don't understand Some questions are not even answered. Where in the world can I study tyflow? RE: cpu thread? - tyFlow - 06-04-2023 What question is unanswered? RE: cpu thread? - rheogh - 06-04-2023 interpolate tick,phoenix fd There's no answer to this question Was my question too rudimentary to answer? And ordinary people hear those terms I don't understand. So I have no choice but to keep asking questions. The answer to question number 1 What do you mean by limiting the total to the maximum number? I don't know much about processors, I guess Can't you study if you don't know much about computers? RE: cpu thread? - tyFlow - 06-05-2023 What I mean is, the number of threads used by tyFlow is limited to the total number of threads the system can run at one time, minus the number of reserved processors specified in the CPU rollout. And if you set the maximum number of threads to something lower than the total number of threads the system can run at one time, then the number of threads used will be *that* number, minus the number of reserved threads specified. So if thread count is set to "auto" and your system has 32 processors and you set the number of reserved processors to 2, tyFlow will use up to 30 threads. If thread count is set to "10" and your system has 32 processors, tyFlow will only use up to 10 threads. It's usually best to keep "auto" enabled. RE: cpu thread? - rheogh - 06-06-2023 Ok thanks but what I want to know This is an unusual situation. Because I am in a situation where I use various computers at work and at home I don't want to memorize the number of threads I have. So if you want to use all the threads For convenience, enter ex)999 Even if I don't have 999 threads I'm wondering if the maximum thread value I have applies. I hope you understand me because I don't know English. RE: cpu thread? - tyFlow - 06-06-2023 You don't have to enter anything. Just keep "auto" checked. That will automatically use as many threads as needed, given your system. |
