Global scale for Terrain Color - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Global scale for Terrain Color (/thread-3743.html) |
Global scale for Terrain Color - peter.buco - 06-26-2023 Hi, everybody. I have simple terrain flow (birth terrain, terrain noise, terrain color, terrain display) using default scale of terrain 2,5m and terrain color preset. If I want to scale the whole terrain up let's say change birth terrain scale from 2,5m to 25m the whole situation is getting complicated. Not only I need to change scale and strenghts of noise but a a lot of values in color presets. Some values can't even be that high (in my case 10 times higher) My point is that it would be handy to have some kind of global scale for Terrain color which would ensure that your color presets still work for bigger scales. Thank you. RE: Global scale for Terrain Color - d4rk3lf - 06-26-2023 Isn't "Terrain Transform" operator exactly for that? RE: Global scale for Terrain Color - peter.buco - 06-26-2023 (06-26-2023, 10:01 AM)d4rk3lf Wrote: Isn't "Terrain Transform" operator exactly for that?You are right, thank you for help |
