Increase particle behavior curve - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Increase particle behavior curve (/thread-3938.html) |
Increase particle behavior curve - studentliuhua@163.com - 10-21-2023 Can you imagine using curves to control the size, position, speed, and transparency of particles, just like the particles synthesized in the later stage. The curve function in the line in TYFLOW. This can better and more freely control the behavior of particles. 2. Would you consider adding fluids, smoke, explosions, and particles in the future RE: Increase particle behavior curve - studentliuhua@163.com - 10-21-2023 The user's intuitive experience and ease of operation are the most important. Don't give customers a bunch of parameter choices, but let the customer group achieve the best results through the simplest operation. Adding curves can greatly reduce the dryness of operation parameters and flexibly control the controllability of each range and detail. |
