daemon pops up - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: daemon pops up (/thread-3989.html) |
daemon pops up - houou - 11-22-2023 The daemon pops up every time if I just happen to start 2 or more instances of 3dsmax at the same time. ( I do that quite often to copy paste models from here to there and clean thep in other instances ) Tyflow works normally. So it is just the daemon poping up. I guess they try to access a file that it is already beeing accessed. well not a big deal, just heads up about it. RE: daemon pops up - tyFlow - 11-22-2023 I'm not sure what you're referring to by "daemon"? Do you mean the license sentinel popup? If so...hmm...are you starting multiple Max instances at the exact same time? RE: daemon pops up - houou - 11-26-2023 (11-22-2023, 05:44 AM)tyFlow Wrote: I'm not sure what you're referring to by "daemon"? Sorry I seem to have heard that somewhere and realte it to Tyflow, haha, maybe it refered to a "watcher software" Maybe reference to Maxwell Demon? anyways! sorry for the confusion. Yes the popup when Max is starting. And yes I'm starting 2 instances at same time almost. I guess I just need to go slower. RE: daemon pops up - tyFlow - 11-26-2023 Ah, that explains it then. I've tweaked things so that in the next build this issue should no longer occur. Thanks! RE: daemon pops up - houou - 11-27-2023 great! thank you! |
