4K display issues: property panel cut in half - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: 4K display issues: property panel cut in half (/thread-4.html) |
4K display issues: property panel cut in half - tyFlow - 04-01-2019 Known bug, working on a fix. RE: 4K display issues: property panel cut in half - tyFlow - 04-02-2019 Hey guys, If any of you are having the 4K display issue and are running max2019....could you give this build a shot? http://apps.tysonibele.com/tyflow/beta/Download.php?version=tyFlow_2019_016003 It should fix the issue but I want to be sure... RE: 4K display issues: property panel cut in half - gardocki - 04-02-2019 Works for me! On a slightly related note though, the viewport menu overlaps the others when using display scaling: https://i.imgur.com/90R96TH.png RE: 4K display issues: property panel cut in half - tyFlow - 04-02-2019 Oh, thanks for that! I'll make sure that fix shows up in the official next build too. I'm hoping this is related to the other rendering issues some users are reported and I can fix everything in one fell swoop. RE: 4K display issues: property panel cut in half - tyFlow - 04-02-2019 New build is up...this problem should be fixed in all max versions now. RE: 4K display issues: property panel cut in half - Boris268 - 04-03-2019 Yes it's fixed. |
