Working with deadline - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Working with deadline (/thread-4025.html) |
Working with deadline - Booclay - 12-22-2023 I've got a slight problem when rendering scenes with TYflow in them on (thinkbox) Deadline. Essentially the job fails on the deadline queue if tyflow is used. One thing I've noticed is that a couple of the render nodes do complete the frames and they are running deadline not as a service and so under a different user to the other machines on the farm. So my question is, when running 3DS max as a service under another user, could it be that user can't see/access the tyflow plugin? Would seem odd but essentially this is what is happening. I'm not sure if its because its a different user or because its running as a service, but if deadline runs it under user A as a service, it fails but if it runs it as user B not as a service its fine. I'll also post on the deadline forum but I thought I would check here too. RE: Working with deadline - tyFlow - 12-30-2023 Make sure you're using the very latest version of tyFlow. There was a regression a few builds ago where a render slave would crash if the license cfg folder didn't exist on the machine. It has since been fixed in the latest build, but if you're a few builds behind, you might be running into that bug. |
