Name exported particles based on input objects name - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Name exported particles based on input objects name (/thread-4032.html) |
Name exported particles based on input objects name - SeanRedmond - 01-08-2024 Hey, I'm trying to find a way to export particles from a birth objects operator with the exact same name as their input objects. I couldn't find any information on if we can use input tokens to dynamically rename objects in the exported object name (prefix) box. The export layer default is $(activelayer) so I would assume there are other input tokens I can use. If not, any other workaround would be appreciated greatly. Thanks! RE: Name exported particles based on input objects name - v.p.vlasenko - 11-21-2024 same question RE: Name exported particles based on input objects name - tyFlow - 11-21-2024 Particles don't track the name of their source object - in fact they might not even have a source object. You could assign them an ID or something and then use a post-export script to match IDs to names or something like that, but that would need to be done manually. |
