how export groups are working? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: how export groups are working? (/thread-408.html) |
how export groups are working? - SiriVFX - 04-17-2019 i try to export particles in different groups, to apply different material after that. but if i use global export(export node in a single event) it seems to export every visible particle. thought i turn on export group A in display node and export node it would only export all A marked particles. but the particle disappear when i select a a group in the display node. if i put the node in an event it exports only the particle in that event. and i also dont know what this overlapping/equal/not equal does. RE: how export groups are working? - tyFlow - 04-17-2019 You have to assign groups with a Particle Group operator. The group checkboxes in other operators then filter out particles based on your assignments. RE: how export groups are working? - SiriVFX - 04-18-2019 but what effect or purpose has the tyActor Property than, where i can set export groups too. same with export group at the display node. RE: how export groups are working? - tyFlow - 04-18-2019 If you assign tyActor properties to geometry, tyFlow will import those properties and assign them to the corresponding particles. In that case you wouldn't need a Particle Group operator. |
