Bind volumes ? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Bind volumes ? (/thread-4118.html) |
Bind volumes ? - Gregory - 02-22-2024 Hello, How can I bind a volume of particles on to a deforming object? Imagine a deforming sphere. filled inside with particles. Object bind doesn't really work, as it needs to use "Snap to Surface" for the particles to follow the deformed object, but then you loose the volume of the particles, as they all go and snap to the surface of the object. What is the correct way to do this? Thanks, Greg Ah, never mind! Figured it out! |
