PhysX Bind Slicing working? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: PhysX Bind Slicing working? (/thread-4190.html) |
PhysX Bind Slicing working? - betamax - 04-02-2024 I just tried Bind Slicing using the tySlicer helper and it works fine with ParticlePhysics flow, but not with PhysX flow - using the same/similar setup? Please see the video. It shows bound particles falling through a tySlicer. https://streamable.com/mo9k1u I've checked and added the correct tySlicer helper to each flow's break operator, but no luck. Maybe I'm missing something? Thanks, Max RE: PhysX Bind Slicing working? - tyFlow - 04-02-2024 Can you upload the file please. RE: PhysX Bind Slicing working? - betamax - 04-02-2024 Sure thing, here it is... RE: PhysX Bind Slicing working? - tyFlow - 04-02-2024 Looks like a mistake on my part...the PhysX bind slicer algorithm takes into consideration the motion of a slicer, but not the particles themselves. Will fix in the next build. |
