maxscript for dummies - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: maxscript for dummies (/thread-4376.html) |
maxscript for dummies - HHbomb - 08-01-2024 Hi, Tyfow is becomming the heart of max... I'm sooooo sad to be stucked on max 2022 ( perpetual license ) !!! :-( I'm a dummy scripter, I'd like to add an Object bind surface Object , or a Birth surface Object to a Tyflow object.... Is it possible by maxscript ? Could I have an exemple ? For some people it take 20 secondes, for me it take 1 year... Thanks. RE: maxscript for dummies - tyFlow - 08-01-2024 There's not currently a way to add operators/events to a tyFlow object with MAXScript (it's on the todo), but if you have an existing tyFlow object already populated with events/operators, you can modify those operators with MAXScript. For example, if you have a tyFlow object with a Surface Test operator inside of Event_001, you could add a selected object to it like this: Code: append $tyFlow001.event_001.surface_test.objectList $ |
