Doubled frames in animation - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Doubled frames in animation (/thread-4429.html) |
Doubled frames in animation - Fabrice - 09-02-2024 Hi, I animate hair (2d cards with opacity) growing along an animated spline. When I (network) render the result is a bit jagged on some part of the sequence. It appears that some frame are "doubled", everything moves normaly in the scene execpt the tuflow growth wich sometime stops for 2 frames and then goes on. The network rendering is over 2 identical PCs so the bug should be regular every 2 frames but it's not. I tried lowering the Time step without changes. Is it a known issue? Is there any solution? RE: Doubled frames in animation - tyFlow - 09-03-2024 No, that's not a known issue. I would always recommend caching out a flow before netrendering regardless. Avoids any issues related to different results being generated by different machines. RE: Doubled frames in animation - Fabrice - 09-05-2024 But rendering local on 1 pc is the same, it-s not a network-only issue. But rendering local on 1 pc is the same, it's not a network-only issue. RE: Doubled frames in animation - tyFlow - 09-06-2024 Does the issue occur if you render with VRay CPU instead of GPU? |
