tyFlow v1.119 - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v1.119 (/thread-4557.html) |
tyFlow v1.119 - tyFlow - 11-08-2024 tyFlow 1.119 is up! https://pro.tyflow.com Additions: * added tyVAT modifier for exporting Vertex Animation Textures in various formats (see docs for more info) * added Optimize operator for optimizing particle meshes * added tyOptimize modifier, which is currently a simple wrapper for 3ds Max's ProOptimizer modifier, but doesn't require users to press "calculate" in order to optimize a mesh (optimization happens immediately/automatically without the need for manual UI interaction first) * added Sort operator, for sorting particles in an event by a custom property value * added CoACD convex hull decomposition mode to Convex Hull operator * added spline convex decomposition mode to tyConvexHull modifier * added vert/face normals option to Surface Test normals test * added "order by material ID" mode and "sort faces by vertex order" option to tyVertexOrder modifier (for deterministic Max-to-Unity FBX submesh sorting) * added "split elements" option to tySelect mesh selection mode, for controlling whether mesh elements will be split up prior to performing inside/outside test * added option to remove mesh faces by material ID in Shape Remove operator * added options to pre-delete matching objects by name/layer in Export Particles operator * added option to close all subsplines in tySplines object * added "invert" option for various relative-to-property parameter blocks, to invert result of relative multiplier * added "UVW values" selection mode to tySelect modifier, for selecting vertices based on baked mapping values in a mesh * added search mode options to Property Test binding search mode * added transform direction unification settings to Rotation operator's oriented bounds settings * added direction options to Point Force operator * Spline Paths operator create new spline paths button functionality now exposed to MXS * Export Particles operator has a "visibility to zero" option now, for animating the visibility of objects when their corresponding particle dies (rather than scaling them to zero) * added explicit normal alignment support to Rotation operator * Modify Bindings and PhysX Modify operators now have more advanced interpolation settings * adding culling options to tyMultifracture modifier plane rollout, for culling fracture planes based on whether or not they intersect a gizmo bounding box * added custom float interpolation mode to operator interpolation dropdowns * added noise sample source options to Speed operator * added "outwards from neighbors" and "outwards from event particles" mode to Speed operator direction parameters * improved stability of sticky penetrations and made "split compound colliders" optional within the PhysX Shape operator (see docs for more info) * added Script operator timing rollout option to evaluate after PhysX step * added Z-position sorting methods to PhysX Bind operator, for binding to highest/lowest particles in radius * added new boolean (true/false) test value options to Property Test operator * added sort by ID option to Export Particles objects mode, for exporting objects in the order of their birth * added loop/variation settings to Birth Spline operator's spline offset settings * added "NewParticles(int count)" function to Script operator, which is much faster than calling "NewParticle()" repeatedly for large numbers of new particles * added "custom TMs" location mode to Multifracture operator's planar fracture location dropdown * added "last N particles" and "particles before last N" mode to Split operator Fixes: * improved reliability of mesh convex hull algorithm * fixed an issue where the Birth Flow/Flow Update operators were not preserving explicit normals of meshes imported from a legacy particle interface * Array operator's circular array mode will now prevent coincident first/last particle generation * fixed a rare crash that could occur when using noise curves in a multifracture operation * fixed an issue where the Script operator could fail to retrieve certain properties from meshless objects * fixed an issue where the Weld operator wasn't respecting particle pivot offsets * Limiter velocity limits no longer clamped to max/min of 0 * fixed some issues with the "relative to property" settings of the PhysX operator and Mass operator * fixed the "relative to property - invert" algorithm (it was not producing correct inversions relative to the min/max range) * PhysX bind breaking must now be explicitly enabled in the PhysX Modify operator in order to modify break thresholds * fixed an issue where the inherit velocity parameters of the Position Object operator weren't working properly in pivot scatter modes * fixed an issue where the closest-point mode of the Position Object operator wasn't respecting the surface offset settings * fixed an issue where selecting events with non-default evaluation orders could cause a flow to reset * fixed an issue where selecting multiple non-instanced tyFlow objects/modifiers and then changing a setting that causes their rollups to be regenerated would lead to a crash * fixed an issue where if an operator was instanced using SHIFT+ALT, the next non-instance copy created by only holding SHIFT may still instance it * fixed an issue where the Birth Splines operator wasn't properly inheriting spline material IDs in some scatter modes * Cluster operator seed now affects overall LDNP distribution * fixed an issue where the Export Particles operator (in object export mode) would not set keys on the last export frame if subframe keyframes were enabled * fixed an issue where the Birth Objects operator would not properly track input object transforms if "inherit object geometry" was disabled * tyDiffusion image lists now have options to move images left/right in list in image right-click menus * fixed an issue where tyCaches might not transfer particles through their interface if frame clamping is enabled and the start/end frame are the same * fixed an issue where some operators may continue to display their internal data after simulation refresh even if the flow is modified to exclude them from evaluation * fixed an issue where tyCaches would not properly display the explicit normals of their meshes if their transform was rotated * fixed an issue which could lead the Particle Physics operator to freeze depending on selections made within its simulation group settings * fixed an issue where an input object in a Birth Paint operator could mistakenly cause a flow to continually reset * fixed a rare crash that could occur if PhysX reports an error inside a mesh construction thread * set tyDiffusion numpy version requirement to 1.26.4, which should hopefully alleviate errors some users were running into during install * fixed an issue that could cause a crash if splittable constraints are torn in a thread * fixed some issues related to script-accessible mesh handling in the Script operator * fixed an issue where the tyMultifracture modifier wouldn't paint slice strokes properly if the target object was rotated * fixed some issues related to how tyFlow's internal mesh class computes its accelerated data structures in threads, which could previously lead to crashes in certain situations * all custom property types (float/vector/tm) will now be cached by default * fixed an issue where the Multifracture edge fracture algorithm was improperly slicing along degenerate faces * fixed an issue where objects referencing a tyCache (ex: tyMesher) wouldn't update properly when the tyCache was cleared |
