Can the color of an object be transferred to tySplineMesher using particles? - Printable Version
+--- Thread: Can the color of an object be transferred to tySplineMesher using particles? (/thread-4601.html)
Can the color of an object be transferred to tySplineMesher using particles? - Harakudash - 12-16-2024
Hello.
Is it possible to emit particles on the surface of an object and save the object's texture color to a custom vector?
Also, can I use the values of that custom vector to color the tySplineMesher?
Other than the above, is there any other way to transfer the color of an object's texture to a particle and then spline that particle to transfer the color to tySplineMesher?
I'm using a translation tool, so sorry if the context is wrong.
RE: Can the color of an object be transferred to tySplineMesher using particles? - tyFlow - 12-17-2024
Yes you can transfer the color values to a mapping channel of your choice, then use a Vertex Color texmap on the splines to extract the colors and turn them into something your material can read.
RE: Can the color of an object be transferred to tySplineMesher using particles? - Harakudash - 12-17-2024
(12-17-2024, 02:20 PM)tyFlow Wrote: Yes you can transfer the color values to a mapping channel of your choice, then use a Vertex Color texmap on the splines to extract the colors and turn them into something your material can read.
Thank you for your response.
I will try it and if I am not sure, I will ask again in the thread.
