Chaos Cosmos Objects Scatter problem - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Chaos Cosmos Objects Scatter problem (/thread-4679.html) |
Chaos Cosmos Objects Scatter problem - jaros - 02-16-2025 Hi, when i try to scatter a "chaos cosmos object" (like a rock) on a "tyflow terrain" using terrain scatter it works fine but when I save the scene and restart max (2022) and reload the scene again it doesn't work anymore and won't show up in render anymore. How can I make it showup in render again? Hope somebody can help me. Cheers RE: Chaos Cosmos Objects Scatter problem - jaros - 02-16-2025 (02-16-2025, 07:15 AM)jaros Wrote: Hi, So, i found out that turning off "Convert local file paths to Relative" in max preferences (files) and resave made it work again. Not sure whose fault it is in the end and if it's a tyflow/max/cosmos bug or perhaps no bug at all. |
