tyFlow v1.125 - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v1.125 (/thread-4706.html) |
tyFlow v1.125 - tyFlow - 03-04-2025 tyFlow v1.125 is up! https://pro.tyflow.com Additions: * added value retargeting options to Value operator * Value expression textbox can now be expanded to a separate window * added output node to Value events (note: currently this node cannot be connected to other Value events - only directly connected to exposed spinners) * added tySelect soft selection noise modes * GetFloat(name, frame, simIndex) function added to Script operator, for interfacing with connected Value operators that are dependent on particle properties * added mode in Display Data operator to only display data for selected particles (also added ability in Display Data operator to select particles) Fixes: * fixed a few miscellaneous Value-operator related issues * fixed an issue where Edit Spline changes on a shape wouldn't trigger a Birth Spline reset * tyWeld will now preserve explicit normals, if they exist * fixed a regression which could result in the Particle Break operator breaking too many bindings in "per step" mode * tyMesher (in collapsed mesh mode) should now preserve input object explicit normals * fixed an issue where history-independent mode of a flow wasn't working properly during particle export * fixed an issue where Value events connected together weren't passing the proper Value operator stack to exposed spinners in some cases * fixed an issue where Value operator output couldn't connect to multiple Value events * Vertex Color operator now has RGB type-in mode (with Value operator support) * fixed an issue where tySelect soft-selection noise wouldn't work in some selection modes, when "override existing" soft-selection enabled * fixed a regression where enabling/disabling benign, non-sim operators (ex: Display) could reset the sim |
