tyFlow v1.127 - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v1.127 (/thread-4785.html) |
tyFlow v1.127 - tyFlow - 05-14-2025 tyFlow v1.127 is up! https://pro.tyflow.com Additions: * added support for 3ds Max 2026; ended support for 3ds Max 2018-2019 * added noise and color modes to Value operator * added follow force component to tyVortex force * Value operator expressions now have total particle count and event particle count variables * added boolean test mode to operator filters * added pivot settings (bottom or center) to Position Icon box mode * added surface area property to Value operator * Set Target proximity mode can now take both min/max radius values * added Bounds X/Y/Z tests to operator filters and Property Test operator Fixes: * fixed a rare issue where mesh cache meshes could persist past scene reset, triggering further issues down the line * fixed an issue where the Birth Splines operator wouldn't birth particles over time * fixed an issue where the tyVAT modifier could crash if set to a data channel higher than all initialized map channels on the underlying mesh * fixed an issue where Cloth bind meshes were losing their material IDs * fixed an issue where verlet mode of the Object Bind operator would generate unexpected velocities when sim time scale set to something other than 1 * copy+pasted operators will now expose the same value inputs as their source * fixed an issue where the tyConform modifier could apply double transformations to output vertices in cases where dependent objects are linked to other objects * fixed an issue where the Shell operator was generating incorrect edge UVs * fixed an issue where copy+pasting certain Value operator setups to a separate flow could cause a crash * fixed an issue where the tySelect modifier may not update correctly if its parent object was transformed * fixed an issue where particle pivot offsets wouldn't be properly displayed in tyCaches * fixed an issue where the internal validity of the tyBoolean modifier wouldn't be updated properly if input meshes had no faces * fixed an issue where trying to change a tyCache modifier output path wouldn't work |
