tyFlow v1.128 - Printable Version
+--- Thread: tyFlow v1.128 (/thread-4809.html)
tyFlow v1.128 - tyFlow - 06-06-2025
tyFlow v1.128 is up!
https://pro.tyflow.com
* updated PhysX SDK to 5.6 - external PhysX CUDA DLLs no longer required
* PhysX CUDA and TGS solvers now support sticky penetrations
* v1.128+ DLOs now packaged for download in RAR archive (previously ZIP) - RAR offers superior compression and smaller download size (DLO size has grown substantially after upgrade to PhysX 5.6)
* fixed an issue that could cause Max to crash when resaving a file using a tySelect modified with select-at-frame enabled
* fixed an issue where enabling value operator input for a spinner could prevent the value operator input from being toggled off
* fixed an issue where Birth Flow/Flow Update operators were not properly interpolating tyCache shape pivot offset values
* fixed a race condition that could cause the Multifracture operator to crash
* fixed an issue where actors importing other particles were not properly importing their pivot offsets
* fixed an issue where tyConform vertex selections were not working if vertex inside/outside filters were enabled
* fixed an issue where the Terrain Export operator was not exporting sequences properly in history-independent mode
* fixed a regression where multifractured chunks were rendering in offset positions
* fixed some issues with tyFlow’s perlin/simplex curl noise implementations
* fixed an issue where tyFlow Alembic mesh export was exporting Y-up meshes/transforms with negative scale
* fixed an issue where node dependencies would not be reset properly when tyConform modifiers copied between objects
RE: tyFlow v1.128 - HHbomb - 06-10-2025
Hi, I just downloaded several times ( with explorer and chrome ) "tyFlow_1128.rar" and when I try to unrar I get "no archive found"
Win 10 french with winrar
Just install winzip76 : I can unrar the archive. Perhaps to old winrar
Thanks for Tyselect issue. I had max crashes at scene reset with "heavy" scenes and I wasn't able to know where it come from.
These Tyselect didn't have select at frame enable. But it solve my problem !
RE: tyFlow v1.128 - tyFlow - 06-10-2025
Thanks for letting me know. I RAR'd it using WinRAR 6.20, with default settings.
RE: tyFlow v1.128 - HHbomb - 06-11-2025
(06-10-2025, 01:04 PM)tyFlow Wrote: Thanks for letting me know. I RAR'd it using WinRAR 6.20, with default settings.
My version is 3.93.0.0    Big Grin    Yeah it is a little bit old.  Tongue ( but as it is the first time I have a problem I didn't mind )
I have a scene with a Xref file.
In the Xref file there is a large poly with Tyselect.
Since v1.128 I can't work anymore on the scene because of this Xref : cpu works a lot, and max no response.
When I open Xref and convert to mesh ( no more Tyselect ) all is OK.
But even if it was a bit slow before v1.128 it was workable.
