Frequency Setting: Max 20 Material IDs? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Frequency Setting: Max 20 Material IDs? (/thread-4852.html) |
Frequency Setting: Max 20 Material IDs? - sushi - 06-27-2025 こんにちは、初めまして。 現在、大勢の俳優が歩いているシーンに取り組んでおり、TyFlow を使用して、頻度設定でマテリアル ID を割り当てています。 疑問に思ったのですが、この方法を使用して 20 を超える異なるマテリアル ID を割り当てることは可能でしょうか? 参考までに、私はスキャンライン レンダラーと TyFlow バージョン v1.120 を使用しています。 ありがとう。 RE: Frequency Setting: Max 20 Material IDs? - tyFlow - 06-27-2025 The Material frequency options are limited to 20 material IDs, yes. If you need more, you can use the Script operator for full control. Also in the future please translate your text to English before posting, so all users can see what your question is. RE: Frequency Setting: Max 20 Material IDs? - sushi - 07-03-2025 Thank you very much. It seems that the text was mistakenly translated into Japanese when it was sent. I apologize for the inconvenience. I'll do some further research on the Script Operator. The original text before translation is as follows. -------------------------------------------------------------------------------- Hello, nice to meet you. I'm currently working on a scene where a large crowd of actors is walking, and I'm using TyFlow to assign Material IDs via the Frequency setting. I was wondering—would it be possible to assign more than 20 different Material IDs using this method? For reference, I'm using the Scanline renderer and TyFlow version v1.120. Thank you. |
