how to modify/add the gravity in tyflow - Printable Version
+--- Thread: how to modify/add the gravity in tyflow (/thread-4899.html)
how to modify/add the gravity in tyflow - peppereng - 08-11-2025
I'm new to the tyflow and would like to add the gravity to the object. According to the gpt and some tutorials, there should be an "physX" tag in the options, where I can modify the gravity. However, I could only find tags like "physX shape" or "physX shape" in my tyflow GUI. How should I fix this and how shold I add the gravity to my object?
Thank you very much!
RE: how to modify/add the gravity in tyflow - d4rk3lf - 08-12-2025
You add gravity by adding "force" operator into the event, and within "built it gravity" you make strength negative number.. example... -1.0
That is UNLESS you are using PhysX shape operator, because PhysX solver will automatically apply gravity, and the options for that gravity can be accessed when you select TyFlow itself, go to modify panel, and it's within PhysX rollout.
