Particle Binding Stretching. - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Particle Binding Stretching. (/thread-4930.html) |
Particle Binding Stretching. - houou - 09-05-2025 This might be a basic question, but why If I stretch a rope, only the bindings on the edge of it will stretch way more than the other? Is there a way to neutralize this so they stretch evenly? I've been trying for a while with the binding properties and no luck. I tried to create custom bindings for the edges... also no luck. hmmmm I noticed that increasing the time-step will make the rope to be more "tense" when moving up and down which is desirable, but the binding still will stretch a lot. Thank you! RE: Particle Binding Stretching. - tyFlow - 09-05-2025 Make sure object-bound particles (the end particles) are deactivated with a Particle Switch operator. RE: Particle Binding Stretching. - houou - 09-05-2025 works like a charm now! thank you! |
