turbosmooth with Tycache in mesh mode. - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: turbosmooth with Tycache in mesh mode. (/thread-4939.html) |
turbosmooth with Tycache in mesh mode. - houou - 09-12-2025 I render with Vray latest versionĀ 7.2 hotfix 2 Using latest Tyflow 1.130 Max 2026.2 When I set a cached cloth sim with TyCache in Rendering - Mesh mode with a Turbosmooth on top, disapears. Meshsmooth works fine though. Do you happen to know if this is Tyflow, Vray or Max fault? I recall this happening in the past too... RE: turbosmooth with Tycache in mesh mode. - tyFlow - 09-13-2025 Yes, it's a Max issue. Use Meshsmooth instead when necessary. |
