tyspline export - Printable Version
+--- Thread: tyspline export (/thread-4952.html)
tyspline export - houou - 09-23-2025
I can't send the file as is, so I'll prepare another file, but in the meanwhile what I'm struggling with is:
I have this scene with lots of splines, when I export them as a tyspline the RAM little by little, frame by frame goes filling up.
The scene is heavy but seems is able to handle it but the fact that the simulation goes filling the RAM makes it impossible to complete.
With particles only no issues it stays even, is just when I want to export the splines, seems as if tyflow is keeping some data in ram even though shouldn't be required?
If something the splines even dissapear at the end but the RAM never goes back, not even after I deactivate TyFlow for that scene.
Things I tried:
► deactivate all the caches, for the tyflows and the tycaches.
► check the "only compute this frame" checkbox in the spline
Any idea?
RE: tyspline export - houou - 09-23-2025
Here is video and file.
As you can see in the video calculating particles has no problem ram goes up, and then down, all good.
With splines it just creeps up, never ever down... Of course this test simulation worked, but in the real case is longer / much denser it can only complete 200f before RAM getting full...
Any workarounds for this? buy more RAM? Big Grin
.mp4   Ignacio Capture 2025 09 24 00 13 03.mp4 (Size: 4.05 MB / Downloads: 220)
RE: tyspline export - tyFlow - 09-24-2025
tySplines have their own internal cache - you can try enabling "Only keep current frame" in their settings to reduce RAM usage.
RE: tyspline export - houou - 09-24-2025
(09-24-2025, 03:17 AM)tyFlow Wrote: tySplines have their own internal cache - you can try enabling "Only keep current frame" in their settings to reduce RAM usage.
Yes, as I mentioned, I did that already but... not really a big improvement. The ram keeps filling up.
I will try now to render the frame range 150f, in separated sims files to see if I can avoid the memory filling up.
Oh sorry, I missed that you mentioned that in the first post.
No worries, I was miswording the parameter so bad, no surprise you missed that one haha.
I actually can confirm that the workaround of submitting first 0-100 then 100-200 then 200-300 to deadline will clean the memory and allow me to export the full lengh...
Tedious work from my side but at least I can export the cache I need Smile
Let me know if there is any better way to do this!
Thank you!
one more thing
I created 8 exports in the same flow with the different time ranges.
When I submit them into Deadline ask me if I want to group them... I say NO.
Then submits 1, popup appears, Ok, and ask me again if I want to group.... No.
Pop up appears.. after completion, and ask me yet again...
and like that for 8 times, takes a while to submit, I was hoping I could submit all 8 at once unnatended.
