tyFlow v1.131 - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v1.131 (/thread-4958.html) |
tyFlow v1.131 - tyFlow - 09-26-2025 tyFlow v1.131 is up! https://pro.tyflow.com Additions: * tyFlow CUDA version requirements raised to CUDA 12.8. Ensure you download and install updated tyFlow CUDA DLLs Fixes: * fixed an issue where changing cache offset frame could prevent the tyCache modifier from updating properly * fixed an issue where baking a tyCache modifier cache would refresh the entire object's modifier stack * tyOptimize modifier now performs more internal caching, so results don't need to be re-computed until underlying geometry changes * PhysX Shape operator size mult now works for compound convex/slice shapes * fixed an issue where instanced objects would show tyCache modifier missing asset errors when reloading their file * fixed an issue preventing tyValue and tyTerrainColor texmaps from being cloned with their settings intact * Time Test variation parameter now takes floating point input * fixed an issue where the Flow Update operator would accidentally integrate spin, leading to synchronization issues * fixed some quirks related to clicking on tyFlow curve controls when zoomed in * fixed an issue where tyMesher results were not correct and/or missing particles for certain CPUs (ex: AMD Threadrippers) * fixed some slowdowns that could occur when adding filters to an operator * when "use raw tySplineCaches" is enabled in a tySplineMesher modifier, step/optimize settings in the underlying tySplineCache modifier will be respected * fixed an issue where the Modify Bindings operator could not change an angle binding's stiffness values * fixed an issue where Redshift would not render particles with a pivot offset properly * fixed issues with the tyVolumeObjectExt interface RE: tyFlow v1.131 - Findus - 09-29-2025 Awesome! Thanks a lot! RE: tyFlow v1.131 - nomad - 09-29-2025 thank you |
