Deadline Export - Printable Version
+--- Thread: Deadline Export (/thread-4960.html)
Deadline Export - houou - 09-27-2025
I'm exporting this 14 Tycaches, and I need to click 28 times in total to do so.
I noticed the window text saying there are 13 exports left, doesn't update maybe?
Because It takes so long I could make a video with the "issue" meanwhile.
Is there a way to overcome this?
The video is a bit long because the waiting time to export, you can skip.
Related to that
I need to do this 2 times for two files, so to save some time I proceded to do that at the same time with two max open, but seems Deadline was confusing the exports from each max and was submitting the same job name two times etc... could be also an issue? or was just some random error?
Thank you!
RE: Deadline Export - tyFlow - 09-27-2025
Oh...hmm...yea I could see that being annoying. I'll make a note to suppress that dialog.
RE: Deadline Export - houou - 09-27-2025
Thank you!
If you could consider also adding a way to interrupt the export half way would be also very useful.
takes some time to export so many files to deadline that a mistake can take many minutes...
