How to create stiff bristles without PhysX? - Printable Version
+--- Thread: How to create stiff bristles without PhysX? (/thread-4996.html)
How to create stiff bristles without PhysX? - ldotchopz - 11-04-2025
I want to use particle physics as it's faster, but i cannot get a functioning stiff bristle at all. is it possible?
RE: How to create stiff bristles without PhysX? - Findus - 11-05-2025
Have you tried Angle Bind?
What are you starting from? Splines are probably the fastest solution along with a Birth Spline, then add geometry thickness later.
Maybe Wobble is enough for a really stiff bristles (or if they end up being fairly small on screen).
RE: How to create stiff bristles without PhysX? - d4rk3lf - 11-05-2025
Have you tried particle bind?
I don't think you'll need Particle Physics at all.
Just spawn on splines like Findus said -> strong Particle Bind... maybe add slow...
Bind bottom particles with object bind to the handle.
I never tried it for bristles... but above method should work just fine.
Wait.. I think Tyson or someone created this.. but it was long time a go... maybe worth doing a search on forum (or facebook), though.... it was so long time a go (and Tyflow evolved)... so even if you find it, it might not work.
RE: How to create stiff bristles without PhysX? - GreenDK - 12-05-2025
(11-04-2025, 02:46 PM)ldotchopz Wrote: I want to use particle physics as it's faster, but i cannot get a functioning stiff bristle at all. is it possible?
I am no expert, but maybe this would work?
.max   Bristles.max (Size: 856 KB / Downloads: 155)
