tyFlow v1.133 - Printable Version
+--- Thread: tyFlow v1.133 (/thread-5004.html)
tyFlow v1.133 - tyFlow - 11-11-2025
tyFlow v1.133 is up!
https://pro.tyflow.com
* added "Load .abc as file sequence" option in tyCache objects
* added option in tyCache exporter to save copy of source .max file with cache
* fixed some issues related to how tyPreview interprets viewport gamma settings when saving output to image sequences
* fixed an issue where the iso value was not working in the VDB Mesh operator when meshing an SDF
* fixed some issues related to how Birth VDB converts Y-up coordinates to Z-up coordinates when loading VDBs from file
* fixed an issue where Export Particles operators could be dragged into incompatible events
* improved performance of tyCache point display
* fixed an issue where deleting multiple script-accessible objects from the Script operator simultaneously would trigger multiple script recompilations
* fixed an issue where text couldn't be copied from the Script operator's error log
* fixed an issue where OpenVDB initialization could crash old CPUs that don't support floating point conversion intrinsics
* fixed an issue where Split operator's random % mode wasn't properly interpreting particle properties from Value operator input
* fixed an issue where too many contacts between convex hulls could cause PhysX to crash
* fixed and issue where overlap blending between terrain tiles wouldn't work if the tiles in question were copied out to another event
RE: tyFlow v1.133 - tyFlow - 11-11-2025
Note: v1.133 taken offline temporarily while I investigate a crashing issue.
RE: tyFlow v1.133 - tyFlow - 11-12-2025
v1.133 is back online - the crashing issue should be fixed.
RE: tyFlow v1.133 - dv2000 - 02-19-2026
max crashes a lot with this version
