TyCache (Splines) age problem - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: TyCache (Splines) age problem (/thread-5010.html) |
TyCache (Splines) age problem - pikok - 11-14-2025 Hi. I've been trying to cache tySplines object, and I managed to do so, but the Age channel seems to be non existent and thus creating age based taper effects is impossible. I've created a TyCache sequence (splines) > TySplineCache modifier > TySplineMesher Am I doing something wrong? Thanks for any help! RE: TyCache (Splines) age problem - pikok - 12-01-2025 Are we supposed to contact support directly via email? RE: TyCache (Splines) age problem - tyFlow - 12-02-2025 It's not clear what you're trying to achieve. RE: TyCache (Splines) age problem - Findus - 12-05-2025 You are starting from a cache? In that case, you might have to do a birth spline in a new flow to get your age data back (or rather recreate it). |
