Workflow for Exporting Alembic? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Workflow for Exporting Alembic? (/thread-503.html) |
Workflow for Exporting Alembic? - radcliffe.chris - 04-30-2019 I'd like to be able to export the tyflow deforming objects, etc as an alembic. For example in the tearable cloth example file, can I select the sphere and cloth and simply export as alembic? When I open it in Maya, everything is static. RE: Workflow for Exporting Alembic? - tyFlow - 04-30-2019 Try putting an Edit Mesh modifier on top of the tyFlow (make sure the tyFlow's particle interface is off) and re-export. If it comes out static again, either Maya's importer is broken or Max's exporter is broken, or both. Alembic isn't fully implemented in either yet so I wouldn't be surprised. Eventually the Export Particles operator will be able to export meshes directly. RE: Workflow for Exporting Alembic? - radcliffe.chris - 04-30-2019 (04-30-2019, 04:35 AM)tyFlow Wrote: Try putting an Edit Mesh modifier on top of the tyFlow (make sure the tyFlow's particle interface is off) and re-export. If it comes out static again, either Maya's importer is broken or Max's exporter is broken, or both. Alembic isn't fully implemented in either yet so I wouldn't be surprised. Eventually the Export Particles operator will be able to export meshes directly. Thanks! That worked. |
