Cloth Bind to PhisX... - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Cloth Bind to PhisX... (/thread-5036.html) |
Cloth Bind to PhisX... - MartinDasnoy - 12-17-2025 I’m trying to do something that I can’t quite figure out. I want to make some rigid PhysX particles carry cloth pieces behind them, but I can’t find a way to bind the two together. The idea is to replace and multiply this setup many times, which is why I can’t use a direct Object Bind. RE: Cloth Bind to PhisX... - d4rk3lf - 12-17-2025 If you do it in separate flows, and if you (in PhysX Flow) add a mesh operator and uncheck "render only" 3DS Max will see it as any regular object. Now go to separate TyFlow, set Cloth Bind, surface test, Object bind... reference your TyFlow with PhysX (as it is regular object)... etc... and it will work. RE: Cloth Bind to PhisX... - MartinDasnoy - 12-18-2025 YES!!!! thanks for thys!! |
