Window glass with window frame physx bind and break - Printable Version
+--- Thread: Window glass with window frame physx bind and break (/thread-5039.html)
Window glass with window frame physx bind and break - alessandro.d84 - 12-20-2025
I guys, i wish to break the glass of a window and no problem to do it. The problem is that i did not know how to bind the physx object of the glass to the window frame.
Thanks for helping me
RE: Window glass with window frame physx bind and break - d4rk3lf - 12-21-2025
Add surface test, and pick your frame model... adjust surface test distance parameter
Connect to next event, and add there object bind, and again, reference your frame object.
That way you are telling TyFlow to select particles near frame, move them to the next event event, and then freeze them there.
RE: Window glass with window frame physx bind and break - alessandro.d84 - 12-22-2025
I've solved it usining particles group. With surface test i cannot achive the result for now. I end up with too much or too less piecese attached
