Sort particles based on distance from scene object - Printable Version
+--- Thread: Sort particles based on distance from scene object (/thread-5071.html)
Sort particles based on distance from scene object - Tim007 - 01-26-2026
I know I can sort particles based on position on X, Y or Z. But is it possible to sort particles based on distance from scene object.
I thought it will be easy but there is no such option in Custom Properties.
Thank you.
RE: Sort particles based on distance from scene object - Tim007 - 01-27-2026
please Tyson, is there a way or can you add this option?
Thank you.
RE: Sort particles based on distance from scene object - tyFlow - 01-27-2026
You can save distance to object using a Surface Test (you can set the channel where distances will be saved in the Test rollout).
RE: Sort particles based on distance from scene object - Tim007 - 01-28-2026
(01-27-2026, 02:26 PM)tyFlow Wrote: You can save distance to object using a Surface Test (you can set the channel where distances will be saved in the Test rollout).
oh, ok, thank you Tyson. Dont know I can use surface test for saving channels, have to look at it. Thank you Tyson.
