Tyboolean on tiny objects - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Tyboolean on tiny objects (/thread-5084.html) |
Tyboolean on tiny objects - HHbomb - 02-16-2026 Hi, when I use Tyboolean on "tiny" or little objects it seems to reach a precision limit. It would be great to have an option to increase or decrease this limit per object. At the same times files in cm opened in m for exemple can cause problem. It would be great Tyflow unit independant. RE: Tyboolean on tiny objects - tyFlow - 02-16-2026 tyFlow is already unit independent. Internally Max has no units - units are only for display. tyBoolean had some internal weld thresholds, but they are pretty tiny. How small are your objects? Microscopic? Ultimately you’ll need to post your file so I can see what’s going on… |
