tyFlow v2.004 - Printable Version
+--- Thread: tyFlow v2.004 (/thread-5133.html)
tyFlow v2.004 - tyFlow - 03-28-2026
tyFlow v2.004 is up!
https://pro.tyflow.com
* added support for 3ds Max 2027
* Value operators can now output custom vector values to parameters that take vectors as input (ex: Inferno Emitter > color)
* added "from custom float" mode to Material ID operator
* added blend mask generation option to tyMeshBlend modifier
* added mesh overlap test to Fuse operator
* added temperature units conversion options to Inferno to VDB operator
* added Effects rollout to Inferno Recall operator, with options to modulate density with temperature and velocity
* added curve controls to all Inferno Spline Force modes in order to control effect influence along splines
* fixed an issue where the Terrain FX operator's 'Slate' mode wasn't working
* fixed an issue where tyFlow could fail to initialize when VRay installed to non-default location
* fixed a regression where Birth Flow loading a tyCache might not updating the tyCache correctly, resulting in incorrect particle data being loaded
* fixed an issue where tyPreviewing an Inferno simulation could cause tySplines meshed with a tySplineMesher to be invisible in the viewport
* fixed an issue where Inferno Blast velocity overrides were just multiplying existing Inferno Emitter velocity values, rather than actually overriding them
* fixed an issue where the Inferno Spawn operator would still emit particles even with the emission rate set to very low values
* fixed an issue that could cause the tyMeshBlend modifier to crash when instanced across more than 2 objects
* fixed an issue where zero-values in an Inferno Emitter thickness texmap would still generate thin emission
* fixed a regression preventing per-frame tyCache meshes (ex: spline caches) from being subframe interpolated properly
* fixed an issue where modulated properties of an Inferno Blast operator could not be correctly referenced by other flows simulating Inferno fluids
* fixed an issue where the Display operator's color source channel menu wouldn't show existing float/vector channel names
* fixed an issue where Inferno Display streamline preview wouldn't work properly if volume display was disabled
* tyFlow will now automatically search for CUDA modules in the default ENV variable path ("TYFLOW_CUDA_MODULES_PATH"), as well as the specified path in the tyFlow GPU rollout
* fixed an issue that could cause Inferno display to freeze Max when zooming through volumes
* improved performance of editor redraw for complex flows
* fixed an issue where Inferno Emitter volume emission wouldn't work if emission thickness set to zero
* fixed an issue where Qt gradient controls on a primary monitor with scaling enabled would overlap other controls, making them impossible to manipulate
* fixed an issue where the Inferno Scale operator was inversely scaling the Inferno Display scene scale parameter
* fixed a regression introduced in v1.128 which resulted in overall weakened PhysX bind stiffness
* fixed a licensing issue where license deactivation could occur if the order of network devices in the OS changed
* fixed an issue where disabling "merge input splines" in the Inferno Spline Force operator would result in only 1 spline being added to the simulation
RE: tyFlow v2.004 - tyFlow - 03-29-2026
If you downloaded v2.004, please re-download - I've patched an issue related to color pickers in Max 2026 and below.
RE: tyFlow v2.004 - d4rk3lf - 03-29-2026
(03-29-2026, 04:40 AM)tyFlow Wrote: If you downloaded v2.004, please re-download - I've patched an issue related to color pickers in Max 2026 and below.
Oh my God... it finally works in my Max 24.
Thank you so much... that 3DS Max bug was driving me crazy.. otherwise, I am pretty happy with 24.
Fantastico!
