Tycache + Vray 7 Gpu - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Tycache + Vray 7 Gpu (/thread-5203.html) |
Tycache + Vray 7 Gpu - rodrigolima3d - 06-21-2026 Hello. I had to change my scene from corona do Vray because the animation will be rendered on GPU. The problem is Tycache is not rendering with visibility animation on the tycache. I've tried to change rendering mode from Instances to Meshes or any other combination but had no success. RE: Tycache + Vray 7 Gpu - rodrigolima3d - 06-24-2026 I'm pretty sure someone have faced this issue before XD RE: Tycache + Vray 7 Gpu - rodrigolima3d - 06-25-2026 Could someone from the plugin support say whether is possible or not? RE: Tycache + Vray 7 Gpu - tyFlow - 06-25-2026 Chaos is responsible for the VRay GPU implementation of tyFlow, so any concerns would need to be brought to their attention. RE: Tycache + Vray 7 Gpu - rodrigolima3d - 06-25-2026 Ok thanks. |
