track view - Printable Version
+--- Thread: track view (/thread-5211.html)
track view - todd.44 - 07-03-2026
I am quite new to tyflow. I created a simple animation of bouncing objects and I baked it using particle export. When I reload the file, the baked animation runs correctly, but I cannot see anything to edit in track view. I have the filter set to show everything (including global tracks), but nothing shows up in track view.
Any solutions to this problem would be greatly appreciated.
todd.44
RE: track view - d4rk3lf - 07-06-2026
How did you bake it?
Object export, or TyFlow cache?
If it's object export you should have keyframe on every frame, if it's tycache then you can't access animation via trackview, but in tycache you have options for retiming.
