Shape VRMesh Path Modification - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Shape VRMesh Path Modification (/thread-5223.html) |
Shape VRMesh Path Modification - im.thatoneguy - 07-31-2026 There needs to be an interface with the 3ds Max asset tracking, a simple scriptable interface or else a "Relink Paths" button that lets you select multiple paths at once in the shape node. If you have 50 shapes in multiple nodes, it's a PITA to go through each node, one object at a time and change the file path. Makes portability between jobs an issue. RE: Shape VRMesh Path Modification - TyFX - 08-21-2026 Can tyCollection work for this or no? I'm not familiar with paths on disk in shape nodes yet, but I know tyCollections have saved me quite a few times. Esp when updating meshes in max, since it's not referenced like in houdini, tyCollections live can retain the objects based on either name specification or layer. I do wish there was a script that formatted selected objects names correctly for the name section in tyCollections. If you do use tyCollection for it I believe there should be a way to split out the mesh elements of that collection, but haven't tested it. Edit: Okay just tested it. So, it only gives you the first object listed in the tyCollection, but you can use a tyMesher which you then put your tyCollection into as your object and then put the tyMesher into the shape node instead as a way around this. Found the post here https://forum.tyflow.com/thread-3882.html For it to work you have to say "Split mesh elements" and "Center pivots" RE: Shape VRMesh Path Modification - im.thatoneguy - 09-08-2026 (08-21-2026, 01:57 PM)TyFX Wrote: Can tyCollection work for this or no? It's not about getting multiple objects it's more about getting like vrMesh objects referenced directly in TyFlow. I don't think you can directly reference file paths inside of a tyCollection without creating a vrProxy object. But then you lose some of the native TyFlow Object controls. |
