Convex hull from total particles - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Convex hull from total particles (/thread-5226.html) |
Convex hull from total particles - N-particle - 08-11-2026 Hi there - I have a birth PRT object of 1500 points. I would like a convex hull that wraps the total points but I'm having no luck. I have tried the Convex Hull Operator and the Tymesher+Convex Hull but they are not wrapping the points as a whole object. RE: Convex hull from total particles - tyFlow - 08-11-2026 To do it within a flow, the particles need a mesh and need to be combined. You can apply a simple mesh with a Shape operator, and combine them with an Element Attach operator. Then put the Convex Hull operator after. Also there's a tyConvexHull modifier you could try directly on the PRT object... |
