In version 20 PhysX is worse than18 for this file [SOLVED] - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: In version 20 PhysX is worse than18 for this file [SOLVED] (/thread-606.html) |
In version 20 PhysX is worse than18 for this file [SOLVED] - HHbomb - 05-10-2019 Hi, I skip version 19... But In 18 it simulate well, in 20 no. Very simple PhysX file. RE: In version 20 PhysX is worse than18 for this file - tyFlow - 05-10-2019 There's nothing wrong with the behavior you're seeing. In recent versions PhysX sleep was fixed, so your particles are simply falling asleep with the default PhysX sleep settings. Just adjust them or make the threshold zero. RE: In version 20 PhysX is worse than18 for this file - HHbomb - 05-11-2019 You are right ! Thanks.You are right ! Thanks.
RE: In version 20 PhysX is worse than18 for this file [SOLVED] - HHbomb - 05-18-2019 Hi, I just opened my file in v0.16022 and I have another behaviour... I can't get it working like in 020.... RE: In version 20 PhysX is worse than18 for this file [SOLVED] - tyFlow - 05-18-2019 Please review the version history for info about how PhysX sim group behaviour was modified in v0.16022. RE: In version 20 PhysX is worse than18 for this file [SOLVED] - HHbomb - 05-20-2019 (05-18-2019, 09:05 AM)tyFlow Wrote: Please review the version history for info about how PhysX sim group behaviour was modified in v0.16022. Hi, but I don't use groups... RE: In version 20 PhysX is worse than18 for this file [SOLVED] - tyFlow - 05-20-2019 Sorry, I was on holiday when you posted that second question and the only change between v0.16020 and v0.16022 that should affect PhysX was the group setting, so that was my guess. I've opened your file now in v0.16022 and don't see the issue. Could you elaborate? RE: In version 20 PhysX is worse than18 for this file [SOLVED] - HHbomb - 05-21-2019 (05-20-2019, 02:22 PM)tyFlow Wrote: Sorry, I was on holiday when you posted that second question and the only change between v0.16020 and v0.16022 that should affect PhysX was the group setting, so that was my guess. I was on holiday = Happy to see you have a life ! :-) Could you elaborate? = I'm a Jackass.... (my fault) |
