Low CPU utilization when using "tyCache" - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Low CPU utilization when using "tyCache" (/thread-744.html) |
Low CPU utilization when using "tyCache" - cgdvs - 06-04-2019 HI, Tyson. I found it when I saved ordinary particles. CPU utilization is very low. Most of the time, the utilization rate is only less than 10%. Do you know what the reason is? RE: Low CPU utilization when using "tyCache" - tyFlow - 06-04-2019 The slowness is probably the time it takes to write to disk. Also tyCache compression is single-threaded. RE: Low CPU utilization when using "tyCache" - SiriVFX - 06-04-2019 i realised a big speed difference between exporting and live memory tycache even with m2 ssd with 1,500mb/s writing speed. exporting prt is fast. |
