tyFlow v0.16029 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16029 (BETA) (/thread-770.html) |
tyFlow v0.16029 (BETA) - tyFlow - 06-09-2019 Version 0.16029 is out! http://beta.tyflow.com Additions: * Fluid Force now supports accurate loading of data from retimed PhoenixFD sims * added a tyExtrude modifier which is a modification of the built-in extrude modifier, except tyExtrude respects spline matIDs on extrusion caps * Actor operator now has the option to inherit material from actor nodes for VRay render instances * Display Data operator has the option to display assigned instance material name * added aerodynamic cloth forces to Modify Bindings operator (lift/drag) Fixes: * fixed an issue where 'weld bindings' in the tySplines modifier was welding incorrectly * fixed an issue preventing PhysX particles from being converted into cloth * fixed a bug where deactivated cloth particles could still be affected by inflation forces RE: tyFlow v0.16029 (BETA) - cgdvs - 06-09-2019 The Galaxy sent a congratulatory message. |
