animated Collision obejcts - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: animated Collision obejcts (/thread-845.html) |
animated Collision obejcts - hkroeber - 07-01-2019 Hi some time ago i requested animated collision objects. now i saw that the pont in the Roadmap isnt there anymore. is it implemented or cancelled ? Regards H.Kroeber RE: animated Collision obejcts - tyFlow - 07-01-2019 Are you referring to PhysX collision objects that are created by generating per-face convex hulls, similar to the mode that pflow offers in its PhysX collider modifier? It's cancelled because when I went to implement it, I realized the work required to re-design the PhysX Collider operator to include that was not worth the trouble -- especially when I also realized it's quite easy to do in tyFlow already, with a couple extra steps: Birth Shape -> Face Fracture -> Object Bind (to the Birth Shape input). That will split an object into constituent faces that follow the original mesh animation. From there, add a PhysX Switch (kinematic) and a PhysX Shape of your choice. That will give the intended effect. I may eventually add a preset of some sort in tyFlow to automate the creation of those events or whatever as well. The next batch of example files will include a conveyor belt example, using this method. RE: animated Collision obejcts - hkroeber - 07-03-2019 (07-01-2019, 02:27 PM)tyFlow Wrote: Are you referring to PhysX collision objects that are created by generating per-face convex hulls, similar to the mode that pflow offers in its PhysX collider modifier? Yeah… this was was last step to forget about pflow and thinking Particles … ;-) Thanks for that. Regards H.Kroeber RE: animated Collision obejcts - insertmesh - 07-05-2019 Preset for that would be great! |
