tyFlow v0.16036 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16036 (BETA) (/thread-857.html) |
tyFlow v0.16036 (BETA) - tyFlow - 07-04-2019 tyFlow v0.16036 is up! http://beta.tyflow.com Additions: * added sweep test option to Property Test neighbor search, for searching for neighbors along the entire trajectory of moving particles * added field of view option to Property Test neighbor search, providing the option to limit a particle's search field of view along its trajectory (for example, so it only finds neighbors in front of it, and skips neighbors behind it) * tyBoolean modifier can now take multi-object input, and an option to hide objects after they're added has been implemented * tyBoolean modifier now has option to convert coplanar triangles into polys * editor tabs have icon showing which flow is selected Fixes: * fixed an issue where tyMesher would only operate on the last particle system in its input objects list * fixed an issue where Property Test neighbor group results were not always returning correct values * modified operator drag/drop behavior so any selected events are deselected after an operator is dragged around |
