How does property test output two objects in a collection into corresponding channels - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: How does property test output two objects in a collection into corresponding channels (/thread-930.html) |
How does property test output two objects in a collection into corresponding channels - mr_f - 07-23-2019 How does property test output two objects in a collection into corresponding channels, such as instance tyflow_balloons_001.max RE: How does property test output two objects in a collection into corresponding channels - tyFlow - 07-24-2019 I'm not quite sure what you're asking, but you can assign certain properties to max scene objects directly using the tyActor properties floating dialog. There is a button to open the dialog in the tyActor settings rollout. Once you do that, max will automatically add those properties to actor rig particles generated for those objects. |
