Voronoi Fracture should add generate particles on the edges to create a Voronoi Frag - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Voronoi Fracture should add generate particles on the edges to create a Voronoi Frag (/thread-946.html) |
Voronoi Fracture should add generate particles on the edges to create a Voronoi Frag - Maulen - 07-28-2019 Hello! I want to discuss you and ask you dear Tyson. You can develop a new create tool "Surface Pos". I tested the tyFlow practice and found that there are two options. 1. Creating a simulation of breaking through the export of Objects, then linking the particles - the position of the objects now results excellently 2. Without export, I tried to add a position to the objects of the connection of the particle. but no possible result. Voronoi Fracture would like to generate particles on the edges to create as a result of Voronoi Fracture. No need to export objects. Watch video examples here Download the project here: https://www.dropbox.com/s/6p3lvrjc3tcbbdc/testFrag_objectParticles_01.max?dl=0 |
