After-image Effect - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: After-image Effect (/thread-981.html) |
After-image Effect - jun-G - 08-08-2019 How can I create this effect like after-image of animated character? https://www.instagram.com/p/BlaN28Ilggm/ Birth shape operator can Create only one Instance and it could not be animated. RE: After-image Effect - drawer14 - 08-08-2019 I think it is a loop (( birth>fracture) > send to physx event) , you can check example file tyFlow_voronoiParticleSource_001, to get the loop idea probably the flow goes like this, birth object > convert to cloth ,Object Bind > convert to shape , Voronoi Fracture > physx - and between those you need time tests The cloth event generates reference animated geometry to fracture every few frames. hope it works RE: After-image Effect - jun-G - 08-20-2019 (08-08-2019, 01:16 PM)drawer14 Wrote: I think it is a loop (( birth>fracture) > send to physx event) , you can check example file tyFlow_voronoiParticleSource_001, to get the loop idea I could make a geometry from animated character using Convert to cloth ,Object Bind and Convert to shape . That's a Great idea!! But I have no idea to loop that effect every few second. Could you show me how to do this?
