tyFlow v0.16043 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16043 (BETA) (/thread-990.html) |
tyFlow v0.16043 (BETA) - tyFlow - 08-11-2019 tyFlow v0.16043 is out! http://beta.tyflow.com Additions: * added "Set Target" operator for particle target assignments * added "Link to Target" operator for linking particles to their targets * added "Displace" operator for displacing particle shape meshes with a texmap * "Display Particle Counts" option in editor right-click menu allows you to see particle counts for each event * tyCache object input path can be manually-entered relative path * added tyLibMtl Material for directly referencing a material from a .mat file [experimental] * Resample operator can now resample by target * Custom Properties operator now has the ability to get from target, set to target, etc, for saving/loading data to/from target particles. * Custom Properties operator now has filters rollout * "Valid Target Count" test added to filters rollout and Property Test operator * added "Display in viewport" option to tyMesher, for disabling viewport mesh generation * Property Test can use custom float as the test value * event age/particle age properties added to Property Test * added resampling settings to tyMesher for filling in surfaces with sparse vertices * tyMesher generation can be interrupted/cancelled by holding ESC * group and spin channel inheritence added to Flow Update operator * Birth Flow/Flow Update can now cull imported particles by export groups * Speed operator now accepts any object as input, for 'Center Out' and 'Axis out' modes * Actor Animation operator now has filters rollout * Resample operator can now resample all affected particle's binds (if 'particle binds' checkbox is enabled), not just those joining family/target pairs * Particle Bind and PhysX Bind operators support binding by target * PhysX Bind sibling/parent mode will now attempt to find more accurate closest points between input meshes to anchor bind endpoints from, rather than simply the particle centers * Find Target operator has new setting to find particle's target * Property Test now has "distance to target" test * Property Test has ability to test properties of target particle * tyMesher can now smoothly interpolate UVWs when inherit UVWs is enabled * added raycast offset spinners to tyConfrom modifier, for offseting raycast origin points * Boundary operator behavior can now be inverted (delete/send if inside) * Send Out operator now has timing/filter rollouts * Property Test now has filter rollout * Subdivide operator now has timing/filter rollouts * added ability to change birth event evaluation priority * added weld tolerance setting in tySpline objects, which also allows you to close open spline loops * all Surface Force modes now have divergence setting * Material ID operator settings consolodated into more organized rollouts * Material ID operator now has 20 frequency slots * Material ID operator has ability to bake ID overrides into particle meshes * added "Target Align" option in Rotation operator Fixes: * fixed a regression where Shape operator was not processing multiple shapes in the list * fixed a bug where Split operator "per frame" mode was ignoring operator timing settings * fixed a bug where tyCache particle interface was returning velocities in units that were too large * fixed an issue where tyCache particle interface would crash if tyCache had no particles loaded * fixed a bug where the Subdivide operator was not optimized properly when "relative" mode disabled and particle scales were not uniform * fixed a freeze when retrieving particle meshes from the particle interface * fixed an issue where tyMesher was unnecessarily re-evaluating in certain situations * fixed a crash that could occur in Birth Flow/Mesher/Flow Update when reading data from a particle source that doesn't return proper data values * fixed a crash that could occur in the Birth Voxels operator, if input meshes had multiple elements and min dist to surface value was greater than zero * fixed a bug where Display Data operator was not properly displaying names of material overrides * surface area tests throughout tyFlow now consider particle scale during calculations * fixed an issue that could cause VRay to crash when rendering empty meshes in tySplineMesher * fixed a bug that could cause crashes in some rare situations when using built-in Shape meshes due to improper topology update interval being defined for all default meshes * fixed a bug where the tyCache particle interface was not respecting the assigned coordinate mode of the tyCache when returning TMs * fixed a crash that could occur if an input spline object has a segment with no knots * fixed a bug where tyCache group filters were having opposite effect (ex, filter sim group 1 and all groups except 1 would be displayed, when only group 1 should be displayed). * optimized generation of tyCarve slice meshes * fixed a bug that could cause tyCarve to freeze during long slice operations that involve self-intersecting slice meshes * fixed a bug where the Flow Update operator with an input tyCache or IParticleObjectExt interface would not update correctly if the particle count changed over time * fixed a bug where the Flow Update operator was not properly flagging velocities from tyCaches/IParticleObjecExt interfaces as integrated * fixed a crash that could occur when importing FBX data into a scene with existing tyFlow nodes * Surface Force "diverge" mode removed, as its functionality was neither clear nor particularly useful * fixed some bugs preventing the Particle Physics operator from working properly in non-integrated mode when particles enter the event at different intervals RE: tyFlow v0.16043 (BETA) - SteveDeeGreen - 08-11-2019 Does anyone else have a problem where they can't open the UI? Tried loading the displace scene, and there's nothing in the modify panel. Same when creating a new one. Max 2019. RE: tyFlow v0.16043 (BETA) - tyFlow - 08-11-2019 Ran into this myself about 10 minutes ago, and I know what the cause is. Quick fix is being pushed out and should be up in about 30 minutes. RE: tyFlow v0.16043 (BETA) - tyFlow - 08-11-2019 UI bug should be fixed now
RE: tyFlow v0.16043 (BETA) - SteveDeeGreen - 08-11-2019 (08-11-2019, 08:43 AM)tyFlow Wrote: UI bug should be fixed now Thanks! |
