04-08-2019, 07:33 AM
I noticed that some Influence parameters are set to show world units. While you're still in generic units they make sense - they range from 0 to 100.
But if you switch to a real-world unit such as meters the parameter will clamp at the max value of 2,54m, which makes little sense when the parameter is essentially a percentage value.
Not a big issue, but it would be more intuitive if these parameters only showed generic 0-100 values regardless of what your display units are set to.
